Eddie's Zodiac XL Project
Date:  3-6-2011
Number of Hours:  3.00
Brief Description:  Antenna's and ANL fuse install
Today I installed both the VHF and Transponder antenna's.
Yesterday a friend (Keith) showed me how to terminate the TNC connector for the transponder, the same pretty much applies to the BNC's as well, so today I made up the remaining 3 connectors and terminated them to the RG400 cable. I am using this for both the radio and transponder as it has superior shielding.
The ANL fuse should help reduce noise and also same the panel if the alternator goes nuts.
Comant Bent wip VHF antenna installed
60 amp ANL fuse from alternator to main bus
Transponder antenna installed
