After making the two wedges that you can just see a the bottom of the angle bracket taking up the spave between the forward bottom and rear frames, I deburred and dimpled the forward and rear frame halves before riveting both sides of the forward frame.
The instructions now say its time to cut the canopy? ahhh lots of reading about what needs to happen first.
The skin that you can see with the blue plastic still attached is only clecoed in place as per the instructions.
