Eddie's Zodiac XL Project
RV-7
Drilled the horizontal stab
Tonight I drilled the forward and rear horizontal spars to the rear fuselage deck and uprights.
All the forward bolts have good edge distance and the rears are a no brainer as the uprights had been pre-drilled during construction.
Alignment is almost perfect with only 1mm difference measured from the stab tip to the firewall.
I am pretty pleased with how this has turned out.
Tommorrow night the Vertical Stab....
Stab big picture view
Rear verticals drilled
Forward spar drilled
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
