Eddie's Zodiac XL Project
RV-7
Flap assembly etch primed
After completing the drilling of the flap side covers, the whole assembly was removed and nut plates installed on the rear flap support bracket.
All the parts were then etch primed so I should be able to reassemble tomorrow.
I still need to install nut plates in the forward seat pan tunnel area, I forgot to do these, bugger, they are now quite hard to get to.
Flap brackets removed, nut plates installed on rear support and etch primed
Side covers etch primed
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
