Yesterday and today I cut the L angles required to make the seat frames and then marked out and drilled the angles in preparation for fitting the seat back. This even I back drilled the L angles to the seat back and installed the bottom hinge. It all fits and works very nicely, what can I say its a great kit !!!.
617 hours so far....
Seat parts cut to size and drilled
Right hand seat installed into the fuselage
Close up of hinge used to adjust the seat position forward and aft.
