Brief Description: Installing nut plates into front wheel spats
Only 7 degrees C in the garage tonight, I started installing the nut plates into the front spat, but once my nose started to run from the cold I decided to called it quits. I'll finish the 3 rear nut plates tomorrow night.
Nut plates installed on front sdie of wheel spat
Metal strip pop riveted on the inside to provide support
