Brief Description: Finished Right spat installation
Now besides tidying up the fibreglass and filling the joins and holes, I only have the nose wheel installation to go, that should be fun. I checked the clearance of the rear of both the spats to the garage floor, and the rear tie-down hook hits before the rear of the spats which is good to know. Because of the angle at which I took image 1, makes it look like the spat is about to drag on the ground. (Trust me, it's an optical illusion), check the previous log entry where I got onto the floor to take a shot of the left rear spat.
Right spat rear view
Front view, you can see here the bottom edge needs a little trimming to straiten it out
