These two photo's besides showing the longeron splice and skin over lap which still needs to be drilled (the higher row of rivets at the back will be extended forward to about where the vertical row of rivets can be seen). The skins in these photo's also show that both the front and rear skins have been trimmed to give a 10mm edge distance from the rivet line.
