Eddie's Zodiac XL Project
Date: 12-4-2006
Number of Hours: 0.20
Brief Description: Nose gear bungee
To install the bungee, you need to slip it past the bottom nose gear bearing and then up onto the hook at the rear of the nose gear, you then use your tool of choice, I used my home made one, a square tube cut at 45 degrees, and place the tool through the bungee angle side down onto the front tube of the nose gear and then just lift and slide the bungee off, its that simple, and takes all of 10 minutes including making your own special tool.
My home made installation tool, a piece of square tube cut at 45 degrees, worked really well.
The end result, the bungee installed
