Work has been hectic over the last week, always seems to coincide with me going on holidays, anyway, I got to leave at a normal hour for a change and managed to sneak into the garage to do a little more work on the front fuse. Beside adding some additional strength to the centre of the fuselage, these pieces are also cosmetic, as they hide the vertical L angle extrusions and make for a better looking finish. The doubler is already cut to size and just needs to be fitted, trimed to follow the curve of the fuselage, and drilled to #30 pitch 40.
Left side view of longeron double installed
Right side view of longeron double installed
Left side view of longeron double installed look toward the rear
