Brief Description: Bottom seat stiffener and flap motor support
I got up this morning and finished installing the 40 thou L angle stiffener in the bottom rear seat pannel and then back drilled some of these holes into the flap motor mount bracket. I managed to drill one of the holes a little too close to the top of the seat pannel which resulted in it being slightly elongated. But with the number of holes here I guess I can live with this or just add another rivet in the center of a blank location for added strength. I have not yet pop riveted the bottom seat pannel and rear spar pannel to the fuse floor and this should allow me to have the required access to install the seat belt brackets on the left and right side of the fuse. I will do this next before moving onto the rear baggage compartment floor.
40 thou L angle in the top of bottom rear seat pannel plus the flap motor bracket
