Brief Description: Nose gear and front seat pannel
This evening I tapped the nose gear bush to take the 1/4 inch bolts, I borrowed the taps from Dusan and per his suggestion put them in the drill press and rotated it by hand, ver easy to control and I am pleased with the way they turned out. I also started making the cutout in the front seat panel where it butts up against the fuselage sides.
