I was feeling really tired the last few days of this week, but wanting to keep with the old addage, do a little bit each day and eventually it will be done, I added the last of the L angles to the bottom left and right sides of the fuse. I also drilled the landing gear mount holes out to 3/16 for the bolts that will be placed there, I still need to do this for the rudder peddel bearings and the bottom engine mounts. Once this is done its time to pull it all to bits, not looking forward to this, its starting to look like something and now it all needs to come apart to be deburred, dimpled and corrosion proofed.
Right side bottom L angles back drilled and clecoed in place
Left side bottom L angles back drilled and clecoed in place
