Brief Description: Marked and drilled the pedals and brakes
When I started this job tonight I was not really looking forward to it, but it was so strait forward, it literally fell together. The only adjustment that I need to make, is to take some more material out of the rear of the brake cylinder floor brackets to allow the pedals to travel towards the firewall more. In image 3 you can see that this is the maximum forward travel, and I'd like to increase this a little more. I have also been wondering how I can make the pedals adjustable, and I believe that using rods that connect the pedals to the nose wheel will allow me to achieve this to some degree, I guess we shall see. I have a plan lets see if I can make it work.
Front view, both cylinders drilled and clecoed to the fuse floor
Main rudder pedal bearing positioned and drilled out to 3/16
Both external bearings positioned, drilled and clecoed
