It was a very slow night tonight, cutting the rudder cable exit hole on the left side of the fuse, cutting the Nylon 66 and adding the slot for the cable to pass through was very very painful. I also drilled the extra hole in the front H.S support bracket, see copper cleco
Added the extra hole to pick up the L angle cross brace
Nylon 66, I still need to clean this up somehow, I hate the way it looks, more filing required.
Cut cable exit slot in fuse, made the Nylon fairlead and clecoed in place
