Brief Description: Installed bottom rudder hinge supports
I installed, cut and drilled all the bottom rudder support brackets after flying this morning, the two bolts on either side of the support are actually installed correctly, its just that the rear longerons have not been trimmed yet and are pushing up against the hinge and causing the bolts to sit at a funny angle.
