Brief Description: Drilled nose rib L angles and assembling the rear
I had quite a busy Sunday, first a call from work, travelling to Indonesia tomorrow to help out a fellow employee, so I thought I'd get stuck into getting some work done on the wing. Its amazing how much you can get done when you just keep working at it. I managed to build the entire wing skeleton in an afternoon which I think is pretty neat. Eveything just goes together as it was meant to, or at least I hope it has. One interesting thing though, up till now the instructions have been great, but as I work through the wing, there is less and less hand holding and much more must be determined from the plans...
