We tightened the nuts on the steel bungee to achieve the proper tension. We raised the nose wheel off the ground so the final nut was tightened that relieved the tension on the side straps. We believe it is correct but will need a taxi test to check it. Next, we taped the bottom cowl back on and found the oil hoses were rubbing the side of the cowl. Also, the oil cooler was shifted which we adjusted. The rear of the bottom cowl will need some material removed. We mated the top cowl to the bottom but found it was too long and the lips around the intakes need about 15mm cut off. So I cut off 15 mm from the lips but still need to do the back.
