Started the work day by swapping out a wire on the Aux Fuel Pump switch. It works correctly now. Installed the Ack ELT aft of the belly access opening. Attached the antenna and GPS wire to it. Sat down in the aircraft on the brand new cushions and started to configure the various Skyview capabilities and modules. It will take a while to complete. Had the Dynon Skyview manual in my lap for several hours. After turning the system off I put the trickly charger on the battery as it was reading 11.6 volts. I also put the pax side kick panel in to test the fit. It fit perfectly. The pilot side will be an issue as there are fuel lines on that side.
