Brief Description: Removed brake cylinders for upgrade
Squeezed a terminal on the 8 awg battery wire from the CB to the post on the ExBus panel. Removed the brake cylinders to send back to Matco to be intensified. The advice I have received is that the brakes without this mod are not strong enough. Hope this does the trick. Boxed up the cylinders and will mail tomorrow.
