Doug's Web Site
CH 750 Cruzer
Brakes
7-11-2017
Installed grounding block
Worked on servo cable and installed female D9s. Ran the wires under the seat and out through the console. Positioned and drilled the hole through the firewall for the gounding bolt and forest of grounding tabs.
Servo cable
Firewall side grounding tabs
Cabin side grounding tabs
CH 750 Cruzer Home
1149
Aircraft
Brakes
Cowl
Doors
Fuel
W&B
Windows
Wiring
