Dean wired the pilot stick grip and finished wiring the flap switch to the relay. I worked on cutting and installing the wires to the console USB. I also aired up the tires as they looked a little low. Confirmed the locations for the heater holes and ECU wire bundle. Dean and I also studied how the throttle cables will go through the firewall. The throttle cable will need some flex because of the hinged panel movement. I had to remove a couple of nutplates on the console top because they were interferring with mounting it correctly.
