Brief Description: Turned Master Cylinder brackets around
We discovered today that the pilot brake master cylinders were conflicting with the floor brackets. The cylinders were jamming against the floor brackets. We looked at the rudder stop and were not getting close to the stop. So, we decided to turn the brackets around which would give us unrestricted movement of the master cylinder. It would also give us more throw on the rudder. I had ordered a couple pair of undrilled new brackets so we drilled out the rivets in the brackets and used them to drill the new brackets.
