I found some additional items in the Skyview HDX Pilot manual that needed attention. The limits on the engine widgets needed updating. Checked some of the preferences from previous configuring and changed some. Deano finished tie wrapping the wiring under the console and that is now complete. We got the top wing skins and clecoed them in place with a few clecoes. Want to add a rubber strip between the skins and the top window. Charged the battery with a more robust charger so the Dynon backup battery will charge to its full capacity. It needs to be fully charged so the test will run for 45 min.
