Doug's Web Site
Date:  8-6-2018
Number of Hours:  4.00
Brief Description:  Installed door hardware on Passenger side
Installed the door hardware to the passenger door. Several problems surfaced. I noted that when the front handle unlocks the mid latch it does not clear the longeron. I cut about 3/8" standoff from 3/8" fuel line for the front handle to sit further from the door. Also, the front handle will need to be bent to give clearance with the striker plate. I installed the rear latch pin that engages the rear latch pin angle and it is binding. I did drill the latch pin guide at an angle of around 15 degrees but maybe the pin will need to be bent a bit. Also the rear latch pin will need to be shortened and tapered again. All told the movement is tight and needs to be adjusted.
Door hardware
Door hardware
Front handle
Front handle
Mid latch and rear pin
