Applied 6800 adhesive to windshield rubber boot and installed a screw to help hold the windshield flat against the fuselage. Applied a strip of butyl tape to Z channel and then screwed it with 6-32 screws into pre tapped cage. Had drilled the windshield holes to 1/4" to insert 1/4" piece of tubing to buffer the screw.
