Doug's Web Site
Date:  5-24-2018
Number of Hours:  5.50
Brief Description:  Pilot mass weights, splice plates
Today I accomplished three tasks. I intalled the mass weights to the pilot side flaperons. Drilled the holes in the steel mounts and expanded holes in both the weights and wing. I installed the wires to the wing plug for the airleron trim. Lastly I cut the splice plate and drilled the holes in the inboard flaperon. The splice plate provides the 15-17 mm of washout between the flaperons.
Hooked up trim wire
Hooked up trim wire
Drilled and mounted weights
Installed splice plate
