Brief Description: Mounted both baffles, fuel lines, oil cooler
Today was busy. I removed the oil filter and tried to remove the oil temp sensor plug. I ended up stripping the hex teeth in it and was not able to remove the plug. Tried to get pliers, vise grips and other metric hex keys to no avail. After several calls to Ray at UL I am still at square 0. He said I could use the plug behind cylinder 4 but it was too small for the oil temp sensor. I will have to figure out another way to get the plug out. I moved on and mounted both baffles. Built a T with various reducers to mount the oil pressure sensor and another oil pressure sensor for the oil press. low idiot light. Assembled the oil cooler and mounted it. Assmebled the return fuel hose, check valve, and return hose to the firewall. Clecoed the fitting for the spark plug wires to the backs of the baffles.
