Installed the ignition coil packs to both sides using Adel clamps. Took longer than I expected trying to insert the nut and bolt through the Adel. Installed the fine fuel filter and attached the fuel hoses from the fuel pump manifold to the filter and then to the engine. I bought the Aircraft Specialty hoses as an upgrade to my FWF kit. They are high quality and fit perfectly.
