Daves Web Site
Date:  1-27-2016
Number of Hours:  3.00
Manual Reference:  20-6
Brief Description:  Wing and Rudder drain holes
One of the CP's has a reminder to put a vent in between the two wing bolt cavities. This is to allow drainage so that the bolt and filltings don't become corroded. Seems a good idea. I found some longlife milk in the kitchen, as I don't drink the stuff myself, that had nice little straws attached. So now you know that when you visit my build I will have some milk for the excellent coffee I serve ...although its better without. Bring your own straws.
So I drilled a little hole in each bolt access recess with the idea that I'd easily connect through the foam and micro in a straw. Over two hours later I had the straws through the holes. You'd think it would be easy. Wrong. I microed them in as you see in pic 2 and I'll carefully trim tomorrow.
The lower winglets got a little drainage hole too per plans. I can see if that section stayed filled with water the rudder bellhorn and cable might start to corrode. I put the hole at the back for the least disruption to the airflow.
Vent as suggested in a  CP
Wing bolt vent
Wing bolt vent
Rudder drain
Rudder drain
