The winglets are done for now. They will need a trim to fit to the wings. I might leave that until later when I am about to do the join in case there is something about how this should be done.
I left the antenna wires long which should reduce wastage. I'll cut the coax after these are threaded through the wings and I know exactly where they will terminate.
Wingtips worked out OK as you can see both sides in pic 2. I can only take so many photos of this stuff. They are nice and functional. Pic 3 suggests I won't need too much filler. I hope not.
Weights worked out at 5lbs each tip. The Melvill weights were 6lbs so I picked up a couple here.... or my scales need calibration.
