Following on from the last log entry you can see I have released the top 'dome' and then made another one.
Pic 2 has a trial fitting of the fittings! AN912-4D inserts which hopefully will accept 269-N06X06 3/8" Nylaseal fittings when I order some.
Pic 3 is after a couple of cure cycles. The fittings are floxed in place and I spent a few happy hours then trimming much of the excess fox away. All that remains is to flox the end pieces on.
Maybe I should have trimmed the fittings a bit too for weight reduction. I was just not sure how the nyloseal fittings work and chose to leave the inserts long. I'll get over it.
