I did a bit of a final check up and its time to find a spot of the canard and move on.
I spent a lot of the day rearranging the workshop and cleaning up as I like to do a lot of the time. Not because I like cleaning, but because I know it helps with a fresh state of mind and will give me a better build. I probably clean the workshop 50 to 100 times more than my home... what does that tell you?
So no hours in the log for this. Perhaps you'd like a few photos. Pic 2 has the canard the fuselage and the wings in shot. The centersection spar is in the corner in pic three. I finally found a place to store the canard on those shelves in pic 3 too.
My next task is the winglets.I spent a good part of the day just reviewing plans and working out where the antenna's will go and looking at shapes in my files.
I also spent a while on the net and asking builder friends about the tops of the winglets as I have to decide NOW.... a plan is forming but I'm not an expert at all on these things so its as much an evaluation and asthetic decison process as aerodynamic.
