Daves Web Site
Date:  10-13-2017
Number of Hours:  4.00
Manual Reference:  no ref
Brief Description:  Finer Wheel Pant Fitting 2
More checking today with the laser. I am happier than I was with the pant alignment now. I have nose and tail and the mid point very very close to where they need to sitr
I have the fuselage up 1.7 degrees which I hope will be ideal for high speed cruise. The pant instructions say between 1 and 2 degrees nose up. My current EZ is around 2.4 degrees nose up at 140 knots and tends to flatten a bit as you go faster so I'm guessing at 1.7 degrees for 180 to 200 knots. Ha!
I'm getting slowly closer. Pic 3 is at a point now where I am checking the midpoints of the halves with the floor to get a zero line in cruise position. This meant that I needed to cut more off the front tire opening. Slowly I'm understanding where to herd all the cats. Once I get the right wheel at this stage I can start adding in the interal pant hard points for the fasteners.
I'm starting to see the way forward with these pants. Lots to do yet but less of a mystery now. Maybe another week? We will see. They will get done and be in the past soon enough.
Side check
Side check
1.7 degrees nose up
1.7 degrees nose up
Getting there
Getting there
