Daves Web Site
Long-EZ
Side Foam cut
Mark out the large .8" sheet of Divnycel foam for cutting into 2 sides. It is over 104" long so perfect for sides without the need to join.
The mark out contours per plans. This took a while as lengths are given every 10" only.
I worked out coordinated inbetween and then found the long sanding block helped join them into a curve.
Full size sheet
Lots of care
Slowly learning
Long-EZ Home
6788
Ch C HeadLight
Ch D Wheel Pants
Ch E Oxygen System
Ch10 Roncz Canard
Ch11 Elevators
Ch12 Canard Install
Ch13 Nose & NoseGear
112
935
Ch14 CS Spar
54
528
Ch16 Control System
Ch18 Canopy
Ch19 Wings & Alieron
122
1066
Ch20 Winglet/Rudder
68
510
Ch21 Wing Strakes
Ch22 Electrical
Ch24 Covers/Fairings
Ch25 Finishing
Ch3 Education
Ch4 Bulkheads
Ch5 Fuselage Sides
Ch6 Assembly
Ch7 Fuse Exterior
Ch8 Rollover/Belts
Ch9 Main Gear& Brake
69
682
ChA Cabin Oil Heater
60
334
ChB Foot Rests
Engine Installation
Ferry Tank
MILESTONES
Pitch Trim
Roll Trim
Strange Tips
Tests
Wheel Pants
Wheel Pants
