Dans RV8
RV8 N14DB
Elevator Trim
Bending Trim
Used the 2x6 brake to bend the trim tab to proper angle.
Cut Bending Blocks. Bends came out great.
Cut the actuator arms to print. Mounted pre-punched part and then drilled the other holes.
Bending Blocks in place
Completed bend
RV8 N14DB Home
1209
187
Cabin Air
197
253
FAA
Organizing
Planning
Skills
