Dans RV8
RV8 N14DB
Avionics Wiring - Power
I have a mix of Amp connectors that are not compatible. I started by figuring out what combinations work.
Next step was to start wiring the powers and grounds.
I wired all fo the left side power to in-line AMP connectors. I still have to connect the mating connector to the VPX.
I adjusted some of the pins on the VPX to better use the available amperage. I created one spare CB for future use.
RV8 N14DB Home
1209
187
Cabin Air
197
253
FAA
Organizing
Planning
Skills
