Fabricated the RG-400 cable for the ADSB transponder antenna and installed. Cleaned up a bit as well, adding cobra mounts to ziptie loose cables.
Spent most time running the 24 ga stick grip wires alongside the center console and out of theway of the rudder cables, fuel lines, etc. Just have to fasten the wires to the torque tube.
Tied the comm antenna cable to the firewall and neatened-up more loose cables behind the panel.
Just have to secure the pitot static lines, but I'm not sure where to turn them due to heat from the firewall, so I posed a question on the Zenith Builders group.
