Zenith CruZer & Sonex Logs
Date:  10-11-2020
Number of Hours:  2.20
Manual Reference:  n/a
Brief Description:  more wiring
No pics.
More wiring - getting close to completion.
Wired hot leads from buss bar to breakers for nav & strobe lights.
Wired starter circuit from PB switch to key switch to firewall. Wired from PB switch to hot side of strobe breaker.
Ran wires from fuel pump up to panel and over to the fuel pump switch & breaker, and to ground block.
Ran ground wires from trim switch and indicator to the ground block. Sorted out what fuselage wires went to the different color Ray Allen wire harness.
