Zenith CruZer & Sonex Logs
750 Cruzer
03 - Wings
7-2-2018
C75-WA-2
Un-Cleco upper skins; begin debur
No pics.
Cleaned up the drill shavings from up-drilling the main spar.
Removed Cleco's from all upper skin surfaces.
Began debur; deburred both sides of nose skins. Deburred upper surface of main spar.
Evaluated pitot tube aluminum assy to determine how close to the main spar the tubing will run when pushed up inside.
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
