First started cleaning the cylinder base mounting pads on the engine crankcase to avoid fretting after they're installed.
Next, I cleaned the hydraulic units for isertion into the tappets. These have to be wiped-down from the shipping coating on the parts. Then they have to be lightly oiled to preserve them against initial startup friction. These go into the tappet bodies, folloed by the pushrod cups, then a retainer spring to keep it all together. Following that, the pushrod housings must be gasketed, installed, and torqued to the crankcase.
Did two of them before family came over. Not much was done this week due to sub-zero temperatures and the inabiliity of my garage to get above freezing. Rough week.
