Brief Description: Panel tidy up and cable install
After some panel work to group wires a bit better etc., I decided to install the remaining control cables for the engine. In the pic below, left to right are the left throttle, mixture, carb heat, cabin heat, and right throttle.
Routed the cables carefully to allow some movem3ent if I remove the avionics stack or individual display screens.
