Zenith CruZer & Sonex Logs
Date:  6-29-2020
Number of Hours:  3.20
Manual Reference:  n/a
Brief Description:  even more punchlist items
No pictures.
Most of the time was spent installing the inner support steel for the main landing gear wheel fairings.Took forever to get the right side off; I couldn't find the right orientation for the 7/16 combo wrench to hold the AN4 bolt that secured the assembly to the main gear leg. Ended up removing the caliper from the caliper support, a royal pain by itself.
Drilled holes thru the gear leg into the spring steel bracket, then reinstalled everything.
When I did the left leg, duh, the caliper slid in, giving enough room such that I didn't need any extra room. No idea why I didn't remember that from the original install.
Reinstalled the wheels and cotter pins, along with inner brake pucks, heretofore uninstalled.
Designed a shelf that will hold the GPS puck antennas for the ADSB and EFIS.
Removed and drilled extraneous rivets in the flaperon control arm covers.
Trimmed the brake lines to the correct length.
