Crimped new terminal on OT sensor line, reattached to sensor.
Added AN fitting to left and right fuel tank hose; clamped, then installed fitting to fuselage bulkheads. Ready to fab new covers for the trailing edge access points I cut.
Connected pitot/static lines to fuselage from wing connections. Used push to connect fittings. Prepped pitot static tube; cleaned and painted, left hanging from wing. Did this to ascertain which tube was pitot and which was static. Will rivet after the paint dries.
After connecting left wing wifes, tested the red left wingtip strobe/light unit. Works great.
Cut flaperon connection plate to correct size, then marked and drilled to prep for riveting.
