Zenith CruZer & Sonex Logs
Date:  4-29-2022
Number of Hours:  2.50
Manual Reference:  n/a
Brief Description:  Rivet Upper Panel Cover
When I installed teh upper panel yesterday, I noticed that the panel cover protruded out further to where it was partially occluding the GPS antennae - at least, the navigation one.
So I set out today to ensure that the antennae could receive. Rats. They could not.
I removed some of the cleco's and raised the right side of the panel up just a bit to provide room. Using metal snips, I cut-back the lip of the panel to show more of the antennae. Retested. This time I got a good signal and depiection of GPS data on the screen. I was even able to track some ADS-B In tracks. Re-cleco'd the upper panel. Checked the reception again - still fine.
Riveted both A5 and A4 rivets holding the panel cover in place. Rechecked recception. Still good. Just didn't want any surprises.
Forgot to take pics before setting the windscreen in place, so you'll have to use your imagination.
