Brief Description: Begin engine cooling baffle installation
I got out the baffles yesterday. Sorted-out where the parts go and felt pretty good about installing them.
Started by just setting the 3 man pieces in place. I decided to try fitting the pilots side side baffle. I don't know whether my Superior Millenium rocker covers are shaped slightly different from the TCM OEM pieces or what, but quite a bit of trimming was required to achieve a non-interference fit. Had to drill-out the prepunched holes for the rocker cover screws and tacked them in place. Will want to clean them up a bit, remove labels, etc.
