Just got back from KS. Checked=over the engine mounts and have decided I want to try and adjust the left lower mount snice it appears to be the most off-centered one of the 4. Will need the hoist.
Checked out the positionin of the crankshaft in relation to the TDC mark on the engine case, then researched the mounting procedure for my wooden prop.
Investigated best spots for mounting the oil pressure sending unit; looks like the engine sump fill tube will be in the way a bit; may have to get creative.
Checked the front strut to axle fork to see how far off I am from the holes required for a front suspension height block to raise the prop off the ground a bit more; it's at 6" now; Roger from Zenith would like to see 8+"
