Cleaned up 16 screw clamps to hole the rubber hoses in place on the intake tubes.
Inserted hoses onto the tube ends, then positioned in place and slid the large hoses over the intake elbows. Clamps were installed loose on the tubes first. Positioned clamps and tightened.
Installed the -3AN fitting into the side of the engine case as the takeoff spot for oil pressure. Installed a flex hose onto the fitting. It hangs loose rignt now, but will be used to remote mount the oil pressure sensor. Sensors have been known to break if screwed directly into the engine case due to vibration.
