Brief Description: Install two remaining cylinders
Got the remaining two cylinders installed - most of the way. I had prepped the cylinders after checking the ring gaps. Installed rings onto the cylinders, then pushed the ring compressor over them. Adjusted the screw clamp to get the compressor "just so." Lubed up everything (bores, pin, piston, etc., then slid it in. Nice and smooth. Installed the 6 hold down nuts and torqued to 25 lbs ft. Installed clamps on the pushrod tube-to pushrod housing bushings.
Repeated for last cylinder. Had a slight problem in that I pushed the compressor a bit too much first time I pushed the cylinder into place and the top ring popped out. Removed compressor , reset the initial position, and it then slid on effortlessly. As above, installed the clamps to the pushrod housings and torqued the hold down nuts to 25 lb fts.
