Brief Description: Wrap up accessory case / prep internals
Ordered and received new "thin" washers to secure the oil pump cover in the accessory case. Installed washers, torqued, and safety-wired the cover bolts.
Also received today the new oil pressure relief spring, so installed that along with the valve plunger and cap on the side of the accessory case. Torqued large acorn nut to spec.
Started to install the 6 pan head screws that hold the (unused) vacuum pump bevel gear to the front of the cam. Got all 6 screws installed and torqued. What a bugaboo trying to safety-wire 6 screws, all separated by about 1/4" gap. I'm seeking some clarification and will regurn to this tomorrow.
Got out the previously reworked crankshaft and mounted it onto the engine stand I bought 3 years ago to hold the engine for dissassembly.
